11-30-2020 03:17 PM
Can anybody help me to fix this issue on Verilog and Schematic? I keep getting this warning that is not letting me give me my simulation,
WARNING:Xst:737 - Found 1-bit latch for signal <D<7>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 1-bit latch for signal <D<6>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 1-bit latch for signal <D<5>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 1-bit latch for signal <D<4>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 1-bit latch for signal <D<3>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 1-bit latch for signal <D<2>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 1-bit latch for signal <D<1>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 1-bit latch for signal <D<0>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
Here is my code:
module rom_content(A,D);
input [5:0] A; //This is the ROM Size
output [7:0] D;
reg [7:0] D;
always @ (A)
begin
if ( A == 6'h00) begin // State 0
D = 8'h00; //ROW 0
end
else if ( A == 6'h01) begin // State 0
D = 8'h00; //ROW 1
end
else if ( A == 6'h02) begin // State 0
D = 8'h10; //ROW 2
end
else if ( A == 6'h03) begin // State 0
D = 8'h10; //ROW 3
end
else if ( A == 6'h04) begin //State 1
D = 8'h2A; //ROW 4
end
else if ( A == 6'h05) begin // State 1
D = 8'h2A; //ROW 5
end
else if ( A == 6'h06) begin // State 1
D = 8'h2A; //ROW 6
end
else if ( A == 6'h07) begin // State 1
D = 8'h2A; //ROW 7
end
else if ( A == 6'h08) begin // State 2
D = 8'h32; //ROW 8
end
else if ( A == 6'h09) begin // State 2
D = 8'h32; //ROW 9
end
else if ( A == 6'h0A) begin // State 2
D = 8'h32; //ROW 10
end
else if ( A == 6'h0B) begin // State 2
D = 8'h32; //ROW 11
end
else if ( A == 6'h0C) begin // State 3
D = 8'h4A; //ROW 12
end
else if ( A == 6'h0D) begin // State 3
D = 8'h4A; //ROW 13
end
else if ( A == 6'h0E) begin // State 3
D = 8'h4A; //ROW 14
end
else if ( A == 6'h0F) begin // State 3
D = 8'h4A; //ROW 15
end
else if ( A == 6'h10) begin // State 4
D = 8'h52;
end
else if ( A == 6'h11) begin // State 4
D = 8'h52;
end
else if ( A == 6'h12) begin // State 4
D = 8'h52;
end
else if ( A == 6'h13) begin // State 4
D = 8'h52;
end
else if ( A == 6'h14) begin // State 5
D = 8'h6A;
end
else if ( A == 6'h15) begin // State 5
D = 8'h6A;
end
else if ( A == 6'h16) begin // State 5
D = 8'h6A;
end
else if ( A == 6'h17) begin // State 5
D = 8'h6A;
end
else if ( A == 6'h18) begin // State 6
D = 8'h7A;
end
else if ( A == 6'h19) begin // State 6
D = 8'h7A;
end
else if ( A == 6'h1A) begin // State 6
D = 8'h7A;
end
else if ( A == 6'h1B) begin // State 6
D = 8'h7A;
end
else if ( A == 6'h1C) begin // State 7
D = 8'h86;
end
else if ( A == 6'h1D) begin // State 7
D = 8'h86;
end
else if ( A == 6'h1E) begin // State 7
D = 8'h86;
end
else if ( A == 6'h1F) begin // State 7
D = 8'h86;
end
else if ( A == 6'h20) begin // State 8
D = 8'h85;
end
else if ( A == 6'h21) begin // State 8
D = 8'h95;
end
else if ( A == 6'h22) begin // State 8
D = 8'h85;
end
else if ( A == 6'h23) begin // State 8
D = 8'h95;
end
else if ( A == 6'h24) begin // State 9
D = 8'hA4;
end
else if ( A == 6'h25) begin // State 9
D = 8'hA4;
end
else if ( A == 6'h26) begin // State 9
D = 8'hA4;
end
else if ( A == 6'h27) begin // State 9
D = 8'hA4;
end
else if ( A == 6'h28) begin // State A
D = 8'hB2;
end
else if ( A == 6'h29) begin // State A
D = 8'hB2;
end
else if ( A == 6'h2A) begin // State A
D = 8'hB2;
end
else if ( A == 6'h2B) begin // State A
D = 8'hB2;
end
else if ( A == 6'h2C) begin // State B
D = 8'hC4;
end
else if ( A == 6'h2D) begin // State B
D = 8'hC4;
end
else if ( A == 6'h2E) begin // State B
D = 8'hC4;
end
else if ( A == 6'h2F) begin // State B
D = 8'hC4;
end
else if ( A == 6'h30) begin // State C
D = 8'h02;
end
else if ( A == 6'h31) begin // State C
D = 8'h02;
end
else if ( A == 6'h32) begin // State C
D = 8'h02;
end
else if ( A == 6'h33) begin // State C
D = 8'h02;
end
else if ( A == 6'h34) begin // State D
D = 8'h06;
end
else if ( A == 6'h35) begin // State D
D = 8'h06;
end
else if ( A == 6'h36) begin // State D
D = 8'h06;
end
else if ( A == 6'h37) begin // State D
D = 8'h06;
end
else if ( A == 6'h38) begin // State E
D = 8'h06;
end
else if ( A == 6'h39) begin // State E
D = 8'h06;
end
else if ( A == 6'h3A) begin // State E
D = 8'h06;
end
else if ( A == 6'h3B) begin // State E
D = 8'h06;
end
else if ( A == 6'h3C) begin // State F
D = 8'h06;
end
else if ( A == 6'h3D) begin // State F
D = 8'h06;
end
else if ( A == 6'h3E) begin // State F
D = 8'h06;
end
else if ( A == 6'h3F) begin // State F
D = 8'h06;
end
end // always ends
endmodule
Thank you in advance!!!
11-30-2020 04:28 PM
What do you mean it is not letting you simulate? Latches can be simulated. Latches should be avoided, but simulation is possible. What error are you seeing when you simulate? The warning is a synthesis warning, not a simulation error.
11-30-2020 09:06 PM
Hi @CotHall433,
When I first look at your code, I realized that you should put an "else" statement at the end of "if" and "else if" sequence because if you do not put it, it may cause latches in your code. Good luck.
Yunus.
