Virtex7 auto generator Block RAM issue
Hello
I want to IP Catlog to Block Memory Generator, but have many of block ram to generator.
Have any tcl script can auto generator block ram?
Vivado 2016.4
Re: Virtex7 auto generator Block RAM issue
You can refer this guide which can help you write tcl script to generate core using tcl commands
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_1/ug896-vivado-ip.pdf
Thanks and Regards
Balkrishan
Thanks and Regards
Balkrishan
Hello @balkris
Thanks for your help!!!
