Virtex7 auto generator Block RAM issue
Hello
I want to IP Catlog to Block Memory Generator, but have many of block ram to generator.
Have any tcl script can auto generator block ram?
Vivado 2016.4
You can refer this guide which can help you write tcl script to generate core using tcl commands
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_1/ug896-vivado-ip.pdf
Thanks and Regards
Balkrishan
Thanks and Regards
Balkrishan
Hello @balkris
Thanks for your help!!!
