Vitis_HLS 2020.2 not starting only splash screen visible
Vitis hls (ver 2020.2) is not opening in the gui mode on windows. I only see a splash screen for a very brief time when I try to run the application.
I search for the issue on the forum and come across: https://forums.xilinx.com/t5/High-Level-Synthesis-HLS/Vivado-HLS-2017-3-not-starting-only-splash-screen-visible/td-p/799934
following which I go to my C:\Users\username\.Xilinx\vitis_hls and delete all the files under this. This fails to resolve the issue.
then i follow https://forums.xilinx.com/t5/Vitis-Acceleration-SDAccel-SDSoC/Vitis-doesn-t-start/m-p/1074165
which asks to delete the .Xilinx folder from the above-mentioned location. When doing so I could delete all files except one file that is xinstall..it says the file is open in another program. I don't see that though..so I restart and try to delete that file, still says the same!
turland
your fix worked for me on Ubuntu 20.10. Thanks!!
anatoli
Thanks everyone for reporting this issue to us (Xilinx) and big thanks to @edmeme for finding a solution that also helped other users on the same problem.
I have reached out to the engineering team to see if this is a know issue/behavior or not, and if not, we can file a request to get this checked and permanently fixed in the latest tools, in case it is still an issue with Vivado HLS 2021.1, that just got released on 06/22.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
