08-19-2020 12:59 AM
Hi all,
I have a project based on ZYNQ UltraScale+ and it is working in Vivado 2020.1. I decided to install that update release of 2020.1.1. After doing so, I can't get that project compiling in 2020.1.1. At first, I needed to modify some IP blocks, then I received so many meaningless Critical Warnings and Error messages. I looked for answers in forum. But, it seems these error or warning messages are related to old Vivado veersions.
Critical Warnings:
[IP_Flow 19-182] Failed to load BOM file '/home/hossein/Embedded/XZY.srcs/sources_1/bd/zcu102_es2_base_trd/ip/zcu102_es2_base_trd_clk_wiz_1_0/zcu102_es2_base_trd_clk_wiz_1_0.xml'.
[IP_Flow 19-182] Failed to load BOM file '/home/hossein/Embedded/XZY.srcs/sources_1/bd/zcu102_es2_base_trd/ip/zcu102_es2_base_trd_dru_ibufds_gt_0/zcu102_es2_base_trd_dru_ibufds_gt_0.xml'.
[IP_Flow 19-182] Failed to load BOM file '/home/hossein/Embedded/XZY.srcs/sources_1/bd/zcu102_es2_base_trd/ip/zcu102_es2_base_trd_dru_ibufds_gt_odiv2_0/zcu102_es2_base_trd_dru_ibufds_gt_odiv2_0.xml'.
[IP_Flow 19-182] Failed to load BOM file '/home/hossein/Embedded/XZY.srcs/sources_1/bd/zcu102_es2_base_trd/ip/zcu102_es2_base_trd_system_ila_0_1/zcu102_es2_base_trd_system_ila_0_1.xml'.
[IP_Flow 19-182] Failed to load BOM file '/home/hossein/Embedded/XZY.srcs/sources_1/bd/zcu102_es2_base_trd/ip/zcu102_es2_base_trd_system_ila_1_0/zcu102_es2_base_trd_system_ila_1_0.xml'.
[IP_Flow 19-182] Failed to load BOM file '/home/hossein/Embedded/XZY.srcs/sources_1/bd/zcu102_es2_base_trd/ip/zcu102_es2_base_trd_vcu_ddr4_controller_0_0/bd_0/ip/ip_6/bd_dc45_lmb_bram_I_0.xml'.
[IP_Flow 19-182] Failed to load BOM file '/home/hossein/Embedded/XZY.srcs/sources_1/bd/zcu102_es2_base_trd/ip/zcu102_es2_base_trd_vcu_ddr4_controller_0_0/bd_0/ip/ip_9/bd_dc45_second_lmb_bram_I_0.xml'.
[IP_Flow 19-182] Failed to load BOM file '/home/hossein/Embedded/XZY.srcs/sources_1/bd/zcu102_es2_base_trd/ip/zcu102_es2_base_trd_system_ila_0_0/zcu102_es2_base_trd_system_ila_0_0.xml'.
[IP_Flow 19-182] Failed to load BOM file '/home/hossein/Embedded/XZY.srcs/sources_1/bd/zcu102_es2_base_trd/ip/zcu102_es2_base_trd_system_ila_1_0_1/zcu102_es2_base_trd_system_ila_1_0.xml'.
[IP_Flow 19-182] Failed to load BOM file '/home/hossein/Embedded/XZY.srcs/sources_1/bd/zcu102_es2_base_trd/ip/zcu102_es2_base_trd_v_hdmi_tx_ss_0_2/bd_0/ip/ip_1/bd_deea_v_tc_0.xml'.
Errors:
[IP_Flow 19-183] Failed to load IP instance 'zcu102_es2_base_trd_clk_wiz_1_0'.
[IP_Flow 19-1835] Failed to recreate IP instance 'zcu102_es2_base_trd_clk_wiz_1_0'. Error reading project file(s).
SynthesisOut-of-Context Module Runszcu102_es2_base_trdzcu102_es2_base_trd_system_ila_0_1_synth_1[Synth 8-439] module 'zcu102_es2_base_trd_system_ila_0_1' not found
[Common 17-69] Command failed: Synthesis failed - please see the console or run log file for details
zcu102_es2_base_trd_system_ila_1_0_synth_1[Synth 8-439] module 'zcu102_es2_base_trd_system_ila_1_0' not found
zcu102_es2_base_trd_system_ila_0_0_synth_1[Common 17-55] 'set_property' expects at least one object.
Resolution: If [get_<value>] was used to populate the object, check to make sure this command returns at least one valid object.
zcu102_es2_base_trd_v_frmbuf_wr_2_0_synth_1[Vivado 12-8300] Launch HLS failed! Please see vivado_hls.log for details.
zcu102_es2_base_trd_v_mix_0_1_synth_1[Vivado 12-8300] Launch HLS failed! Please see vivado_hls.log for details.
bd_dfaa_axi_crossbar_0_synth_1[Common 17-69] Command failed: Unable to run synthesis. No HDL sources found in project
My OS is: Ubuntu 18.04.4 LTS
09-14-2020 02:41 AM
HI @embedded
Why did you install 2020.1.1? Were you looking to use specific devices?
If not you might want to stick with 2020.1 as the update does not include any new feature or fix.
09-14-2020 02:41 AM
HI @embedded
09-29-2020 02:25 AM
This error was a cause of Ubuntu Linux language configuration which was in German. So, it caused problems.
I set the language and other related parameters to English and it was solved.
