Observer williamsf2
Vivado 16.4 compile errors
Hi, Wondered anyone could help with a compile error I cant seem to clear.
Im using a 32bit register and slicing off bits 13 to 28, so bit 0 to 12 are not required. Problem is I keep getting an error saying bits 0 to 12 are unplaced?
Do I ned to tie them off or smthg else even though they are not used?
Here is the circuit with the sliced bits:-
Any help would eb most appreciated..
Re: Vivado 16.4 compile errors
Hi @williamsf2 ,
Use the following tcl commands for OOC flow to resolve the issue,
synth_design -mode out_of_context
launch_simulation -mode "post-synthesis" -type "functional"
opt_design
place_design
route_design
launch_simulation -mode "post-implementation" -type "functional".
Also please check this post:
Raj
Observer williamsf2
Hi, Mny thanks and I will try this.
Could you explain what each line does and why do I need to do this?
