silverace99work
[Vivado 18.2] File replacement bug treats .sv files as .v
Not sure this is the right subsection but I didn't see any better choice.
I'd like to report a tool bug. There is an option in the GUI to replace an existing verilog source file with a different file. When replacing a legacy verilog .v file with a SystemVerilog .sv file, it appears that the tool doesn't switch context to SystemVerilog. It parses the .sv file as .v and so you will get errors such as the tool not understanding what the "logic" type is.
rshekhaw
Hi @silverace99work ,
I guess the Replace By switch only helps with replacing the files specific to one language.
For instance for verilog file, you can replace it by (.v,.vf,.verilog,.vr,.vg...etc):
While if you allow it for all files then you have to mannuly set the fileset.
Raj
silverace99work
@rshekhaw yes that seems to be what it is doing, but the tool should be able to handle that. Instead it drops it on the floor which is why I'm suggesting that it is a bug.
