Vivado 2013.2 IP Integrator - Splitting a port connection to two ILA probe ports
In the Vivado 2013.2 IP Integrator block diagram, I have an analog-to-digital converter, whose output adc_mon_data[59:0], carry the I & Q signals in adc_mon_data[15:0] and adc_mon_data[31:16].
I'd like to split adc_mon_data[59:0], such that I can connect
adc_mon_data[15:0]    to ILA PROBE0[15:0] and
adc_mon_data[31:16]  to ILA PROBE1[15:0]
How can I do this?
Elvis Dowson
Re: Vivado 2013.2 IP Integrator - Splitting a port connection to two ILA probe ports
The Slice IP present in the IPI will serve you the function you want.
Satish
Hi Elvis,
Did you try to use CONCAT IP in block design (you can find it in "add IP")?
Deepika.
Deepika.
Satish
Hi Satish,
Thanks for the solution. The Slice IP block was exactly what I was looking for.
Elvis Dowson
