Vivado 2013.3 IP integrator address editor offset address can not be set beyond 8GB
When I use ip integrator to design a microblaze subsystem, I meet some trouble about high range address setting in address editor.
There are two mig ip in the project, both of them are 8GB. And one address range of them is planned to set from 0x000000000 to 0x1FFFFFFFF, the other is planned to set from 0x200000000 to 0x3FFFFFFFF.  But the address range from 0x200000000 to 0x3FFFFFFFF can not be set correctly, there are some errors reported as below.
ERROR: [BD 41-70] Exec TCL: proposed offset <0xFFFFFFFF> is misaligned for current range of <8G>. The next aligned offset is <0x7FFFFFFF>
ERROR: [Common 17-39] 'set_property' failed due to earlier errors.address_editor.png
Is the address editor not support address range beyond 8GB now?
