Vivado 2016.2 Crashes while editing Package IP parameter with bitstring type
Hi, Vivado 2016.2, Windows.
I am packaging an IP and one of the IP parameters needs to be of type bitstring,
now as soon as I enter a hex value e.g. 0x0 into the default value box (edit ) the vivado window gets closed completely.
Mo.
Re: Vivado 2016.2 Crashes while editing Package IP parameter with bitstring type
@mamisadegh3,
Can you share the test case to replicate the issue? If the issue is reproducible then I will forward the design to factory.
--Syed
hello,
take 2016.2 under windows,
try to package a vhdl file with a generic for which we want to have the default value in hex.
in package ip interface, edit this parameter, and for type select bitstring, and now type something as the default value, e.g. 0x0 or 0
this should show the problem...
