vazquez
Vivado 2017.1 Setting Toplevel generics VHDL
when trying to set toplevel generics (in Vivado/Settings/Project Settings/General/Generics) which are different
from the defaults of those, Vivado 2017.1 does not seem to check the changed values. As a consequence
trying to select different xci files by the "changed" generic leads to an error, Vivado excludes the xci from the hierarchy.
The same problem has been described in
https://forums.xilinx.com/t5/Design-Entry/2017-1-automatic-compile-order-VHDL-gneric-IP-packer/td-p/761914
Could you please shed some light on that important issue?
Rgds
prathikm
Hi @vazquez,
I believe this is something similar to this example like, say: a design having generic WIDTH : integer <some value> declared in top level which is passed to the sub-module. Sub-module has an if-generate statement which uses WIDTH generic and decide whether to generate the IP or not. In 2017.1, synthesis is treating IP (not able to bind generic) as a black_box and hence opt_design fails.
But 2016.4 takes the correct value of WIDTH from top module to synthesize the design and implementation passes without any issues.
This is a bug reported in 2017.1 and a CR-974005 (active) has been filed for it.
Prathik
Helpful answer -> Give Kudos
vazquez
Thank you very much.
Rgds
patocarr
@prathikm
  Bumping this thread to indicate that not only top level generics display the issue, but all generics at any hierarchy level. This is a serious flaw in 2017.1.
  Any idea how to check the CR-974005 bug fix status?
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
nupurs
@patocarr,
The issue shall be fixed in next two releases.
Till then, you can use the workaround of using manual compile order.
Nupur
patocarr
Thanks for the suggestion, @nupurs
Unfortunately, the manual compile order doesn't have any effect on this issue in my testing. The generics are just not replaced as they traverse the hierarchy; only the default value is applied, and optional blocks (ie. generate if) are not evaluated.
Thanks again,
-Pat
