Newbie akcea
Vivado 2017.1 crashes while editing source files
I use a fairly large design and it synthesizes perfectly on vivado 2017.1. I could even do implementation and run the bit file on
FPGA without any problem. Now, the problem occurs when I try to edit one of the vhdl source files. The whole vivado and even the entire system responds extremely slow and it never finish "updating" source files. I could find that a process "srcscanner" consumes the entire memory. In this situation, I am unable to change my design and looking here for any feasible solution. Please help.
Re: Vivado 2017.1 crashes while editing source files
Hi @akcea
Which OS you are using? Check the below link, page 24 for all supported OS with Vivado 2017.1
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_1/ug973-vivado-release-notes-install-license.pdf
With unsupported OS you generally see such undeterministic results. Also try rebuilding  the project from the scratch.
Hope this helps.
Rohit
Rohit
Did you try to edit any IP core source file? In that case please check whether the following AR https://www.xilinx.com/support/answers/69191.html information is applicable for your case.
Also refer https://www.xilinx.com/support/answers/68919.html
Newbie akcea
Hi Rohit,
     I am currently using Ubuntu 16.04.1 LTS which seems to be a supported OS from the documentation.
Arun
Newbie akcea
@umamahe
  I just tried to edit one of my source files which is not belonging to any IP core.
Anyway, I will take a look at the answers provided. Thanks for the links.
