Vivado 2017.4 all files deleted in IP module
I'm not sure what exactly happened, but I had an IP directory structure in an IP repo. Everything was going fine: I instantiated the IP in a block diagram, generated a bitstream. No issues with the IP.
Out of nowhere, I get the info bar saying one of my IP was out of date. I click the link "Report IP Status", and it says the IP files no longer exist. I use Windows explorer, navigate to the IP directory, and every single file is missing in every single directory. The directory structure is still intact, but there is not a single file left.
I'm fairly confident that this was Vivado's doing. The project was located in a local directory, and I had no other programs running.
Very bizarre behavior. Luckily I had just checked in a copy of the code into our version control tool.
Re: Vivado 2017.4 all files deleted in IP module
Unfortunately, I had once the same problem than you. I can't explain what happened, maybe is one out of the thousand Vivado bug.
I don't know if it is the solution, even if it is good to you, but that never happened to me again when I changed the repository folder above project folder.
I mean, if my project is located in:
C:\Projects\Communication_Core\
Then I place my repository folder at the same level:
C:\Projects\Library\
Hope this helps.
Hello @rdb9879,
This topic is still open and is waiting for you.
If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.
If this is not solved/answered, please reply in the thread.
Thanks in advance and have a great day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
