Vivado 2018.1 IP Packager - Preliminary support for VHDL-2008
The "What's New in Vivado Design Suite 2018.1" video linked below mentions that IP Packager now has preliminary support for VHDL-2008 (@ 4:14). Is there any documentation of this preliminary support? UG1118 still says that VHDL-2008 is not supported.
https://www.xilinx.com/video/hardware/whats-new-in-vivado-design-suite-2018-1.html
The Preliminary support comment in the What's New document is in error.  UG1118 is correct and will be the primary document that will be updated when VHDL-2008 support in IP Packager changes.
Hi @rjbohnert,
Have a look into the comments mentioned in this thread which may help you on your query.
https://forums.xilinx.com/t5/Design-Entry/Does-IPI-support-modules-using-VHDL2008/m-p/849171
hemangd
hemangd
