Vivado [2018.2] crashes on Elaborating Design and synthesis always fails
 I have recently started learning VHDL and tried coding a simple combinational design involving two 'or' gates and an 'and' gate. No matter how hard I tried I could not manage to run synthesis. Running synthesis always fails even though there are no warnings. I also can not open elaborated design because Vivado crashes without an error while elaborating. I have tried running synthesis and elaborating design with example codes but they resulted in crashes too. I found older forum posts complaining about similar issues but none of the solutions I found have worked. I thought my non-ascii Windows username could be causing these problems and changed it (without creating a second user). This also did not help.
I am using Vivado on Windows 7.
I am open to any kind of suggestions
Thank you.
I solved all of my problems with pure luck, here is how:
I tried generating bitstream without running synthesis on its own and it magically synthesized without an error. After that instance the run synthesis button worked perfectly.
I was reaching my projects from the open project button on vivado launch menu. I tried opening a project directly from the .xpr file in the project directory, then it magically carried out a perfectly elaborated design.
This might be bug of the version or could just be an issue specific to my computer: Design elaboration hard crashes vivado if the project has been opened from the start menu. If the .xpr file is clicked on and the project is opened this way, open elaborated design button causes no crash.
Thank you all for your suggestions.
Hi @ugy99,
Can you please share a test case in order to reproduce the crash at my end? Also please share the snapshot of any message pop outs during crash, if any.
Raj.
Hi @ugy99,
Try to run Vivado example design and check that you face the same issue with that or not.
Also provide vivado.log from your project directory to evaluate it.
hemangd
hemangd
Amazing...
Thanks from korea.
thank you for your advice. it works.
