Vivado 2018.2 not showing TNS/WNS LUTs etc.
Hi all,
In Vivado 2018.2 (OS: Ubuntu), after implementation has been completed, the tool does not show WNS/TNS, LUT,FF usage etc. in the design runs tab (see pic). Do I have to change some obvious setting? I could see these numbers by default in the previous versions...
EDIT: This problem comes and goes. Sometimes the numbers are shown, sometimes not.
Re: Vivado 2018.2 not showing TNS/WNS LUTs etc.
Hi @cbakal,
Make sure you are using supported version of OS  Ubuntu Linux 16.04.3 LTS (64-bit) for Vivado 2018.2. If not, please upgrade it.
You can also check timing WNS and TNS values by applying tcl command "report_timing_summary" and utilization by "report_utilization".
hemangd
hemangd
Hi @cbakal,
hemangd
hemangd
