igor@cellix
Vivado 2018.3: Address Editor errors [BD 41-1600] and [BD 5-294]
After upgrading to Vivado 2018.3 I started getting the following errors:
[BD 41-1600] /cpu_dp/zynq_ultra_ps_e_0/SAXIGP3/HP1_DDR_HIGH is not addressed by /dma_0/axi_dma_0/Data_SG.
<… and 3 more like these>
[BD 5-294] Error excluding segment
These don't prevent Vivado from finishing bitstream generation however, so it's more like a bug report.
The following IPI pics illustrate the issue:-
BD snipped showing connection to Zynq AXI Slave port causing the issues:
Address Editor showing incorrect Unmapped Slaves (cannot exclude):
igor@cellix
Hi, as far as I remember: It ceased to be an error in the following version. Address Editor was fixed and significantly upgraded with Address Map addition in Vivado 2020.2 and 2021.1. So it's not an issue anymore.
duchungk7
hi igor,
For that errors, do you have fix it ?
igor@cellix
