Vivado 2018.3- can't launch as app on computer
  I've just installed Vivado 2018.3.It doesn't come up as an app on my computer and there is no shortcut on my desktop even though I remember checking that option for a shortcut. Could someone please help. What do I need to run to get Vivado recognized as an app on my computer?
Thank you
Hi @vivienwwp
Would you refer the following URL, if your host OS is Windows ?
https://www.xilinx.com/support/answers/69908.html
Best regards,
I couldn't find the vivado-vg.exe file
Hi @vivienwwp,
to add shortcuts to the Start menu, run the networkShortcutSetup.exe executable.
This file is found under the .xinstall\Vivado_<version>\bin directory.
(For example C:\Xilinx\.xinstall\Vivado_2018.3\bin\NetworkShortcutSetup.exe.
For further details on this and more useful information, please see (UG973) (v 2018.3).
hemangd
When I tried doing that, I got this error and Vivado doesn't launch
Hi @vivienwwp
Check anatoli's forum post in the below-mentioned thread for Microsoft redistributables and follow it accordingly.
https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-Installation-fails-quietly/td-p/948137
And then reinstall your Vivado 2018.3.
hemangd
