Visitor gmehn
Vivado 2018 connect a 7bit bus to 7 pins
I want to connect a b c d e f g pins to the bus Seg0[7:0] on Vivado, see the joined file
Thanks for Help
Teacher xilinxacct
Re: Vivado 2018 connect a 7bit bus to 7 pins
I am 'guessing' from the picture that the issue is you are trying to connect a single std_logic (a, b, c...) to a 'bus' of std_logic (seg0, seg1, ...)... I suspect what you really wanted was not to define the seg# as busses, but single std_logic values (a single pin in a bus), then you should be able to port map/connect them.
Hope that helps
