Vivado 2019.1 Bug in IP Packager
Hi Guys,
I have an IP which contains 2 AXI Masters and 3 AXI Slave ports.
For each port, the IP has also a dedicated clock input.
When packaging the IP in IP Packager in vivado 2019.1 something unsual happens which to me is clearly a bug in the software.
In the ports section, obviously i need to choose the associated clock for each of the interfaces I have.
Now mysteriously, when I select the associated clock for one of my AXI Masters, the associated clocks for some other interfaces change automatically!
And then, when i fix it, vivado removes the associated clock for the AXI Master automatically.
The only way I could solve the issue was to edit the component.xml by hand.
i think this is a bug and should be addressed.
Re: Vivado 2019.1 Bug in IP Packager
Hi @mamisadegh3,
Thanks for reporting this.
I could reproduce the issue locally and I have reported it internally.
Best regards,
Abdallah
Any update on this from Xilinx?
My ip has now 4 axi stream interfaces, 2 axi masters and 2 axi slave lite, and the issue is just getting worst.
vivado does not listen to my set associated clock commands!
Hi @mamisadegh3,
This bug has been fixed.
The fix will be available in the next release (2019.2).
Best regards,
Abdallah
