Observer lematthias
Vivado 2019.1 java error on start_gui with multiple monitors attached (Ubuntu 18.04)
Vivado 2019.1
Ubuntu 18.04 Kernel 4.15 with multiple monitors attached.
Vivado crashes when launching the gui with the following error:
java.lang.IllegalArgumentException: Window must not be zero
Same issue as with 2018.3. No error when only one display is enabled. 2018.2 and earlier versions work fine.
Re: Vivado 2019.1 java error on start_gui with multiple monitors attached (Ubuntu 18.04)
Hello @lematthias .
I have reported this again and have highlighted that there is still an issue in relation to unable to start vivado gui when Multiple monitors are used.
Please leave this with me and I will update you once there are any updates.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Visitor martyo
It isn't the most elegent, but if you ssh into your own box with X11 forwarding, you can launch the GUI and have it X11 forward to yourself.  When you do it that way it thinks there is only one monitor.  I haven't tried this yet with 2019.1, but that worked for me in 2018.3.
Participant nassar
I'm facning the same problem 2018.3 and 2019.1. Is there any updates regarding this issue?
Faraj
Visitor fourier_fft
I'm having the same problem.  Ubuntu 18.04, 3 monitors, NVidia 430 driver.  Java errors on 19.1 won't start the gui.
Observer lematthias
Hi @martyo and thank you for your answer.
Unfortunately ssh with X11 forwarding does not help in my case. Neither for 2018.3 nor for 2019.1.
I am using vncserver for now...
Participant nassar
lematthias,
Im using this script to overcome this problem. I found this solution somewhere here in the Xilinx Forums!
#!/bin/bash
Xephyr :1 -screen 1920x1024&
DISPLAY=:1
openbox&
source /home/nassarf/data/programs/xilinx/Vivado/2018.3/settings64.sh
source /home/nassarf/data/programs/xilinx/SDK/2018.3/settings64.sh
vivado $1
Faraj
