Vivado 2019.1 screen resolution
Hello all,
I am using CentoOS7 in my PC and I installed the Vivado 2019.1. The problem is that after installing it, the Vivado screen appeared with a very bad resolution.
See the photo attached.
Have you ever encountered with this problem?
Thanks and best regards,
baldrism
Re: Vivado 2019.1 screen resolution
Hi @baldrism ,
I guess it might be supported environment issue.
As Vivado 2019.1 supported centos OS versions are 7.4, 7.5, and 7.6 (64-bit).
Please check page no.8 of below link:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug973-vivado-release-notes-install-license.pdf
Thanks and Regards,
Raj Singh.
