thomas_b
Vivado 2019.2 : issue to create Block Design
I installed VIVAVO 2019.2 on windows 10
I created a new project with ALVEO 200 board
I ask to “Create Block Design”
I launch “set clk_wizard [ create_bd_cell -type ip -vlnv xilinx.com:ip:clk_wiz clk_wizard ]
I receive error:
ERROR: [IP_Flow 19-2373] Cannot identify default part.
ERROR: [Common 17-39] 'xit::add_dynamic_interface' failed due to earlier errors.
CRITICAL WARNING: [IP_Flow 19-1747] Failed to deliver file 'c:/Xilinx/Vivado/2019.2/data/ip/xilinx/clk_wiz_v6_0/elaborate/ports.xit': ERROR: [Common 17-39] 'xit::add_dynamic_interface' failed due to earlier errors.
ERROR: [IP_Flow 19-167] Failed to deliver one or more file(s).
ERROR: [IP_Flow 19-3541] IP Elaboration error: Failed to generate IP 'clk_wizard'. Failed to generate 'Elaborate Ports' outputs:
ERROR: [BD 41-134] No portmaps are present on the interface: clock_CLK_IN1
ERROR: [BD 41-951] Parameter FREQ_HZ not found on /clk_wizard/clk_in1
ERROR: [Common 17-39] 'set_property' failed due to earlier errors.
ERROR: [BD 41-1273] Error running post_config_ip TCL procedure: ERROR: [Common 17-39] 'set_property' failed due to earlier errors.
    ::xilinx.com_ip_clk_wiz_6.0::post_config_ip Line 62
create_bd_cell: Time (s): cpu = 00:00:11 ; elapsed = 00:00:11 . Memory (MB): peak = 2063.684 ; gain = 1110.918
ERROR: [Common 17-39] 'create_bd_cell' failed due to earlier errors.
I push the button “add IP”
I relaunch “set clk_wizard [ create_bd_cell -type ip -vlnv xilinx.com:ip:clk_wiz clk_wizard ]
And it work !!
I think that there is an issue at the opening of VIVADO (which do not link the IPs).
Someone has the same issue?
How to solve? Because, when I reopen the project, I have the same issue
andriy_rachek
I've had the same problem (but for XC7A200 chip): my Tcl code where clk_wiz is used did'n work with Vivado 2019.2.
My solution is:
Run Xilinx Information Center, choose "Manage Installs" tab. Under "Xilinx Design Tools Vitis Unified Software Platform 2019.2" press "Add Tools/Device".
Then press "Next" untill "Select Extra Content" window will be shown. Under "Device / Device for Custom Platforms" choose all 7 series family. Press "Next". New devices will be installed.
After this my Tcl code runs without errors.
Same issue for me but for ZCU104 board having Zynq UltraScale+. Reinstalled board repositories but still no luck.
thomas_b
With Vivado 2019.1, no issue.
andriy_rachek
My solution is:
thomas_b
Hello andriy_rachek,
Just adding the "7 series family" devices is resolving the trouble.
Thanks a lot, I was totally stuck.
olupj
This was an issue with the initial release of 2019.2 (SW Build: 2700185 on Thu Oct 24 18:45:48 MDT 2019).
I had the issue targeting the RFSoC (migration from 2019.1 or creating new design in 2019.2, same error).
When I updated to the latest build (SW Build 2708876 on Wed Nov 6 21:39:14 MST 2019) it works.
-Jerry
kahalani
Hi All,
Just to make it clear, if u get above error u should install 7 series devices and it fix the problem regardless device u use
BR
Itamar
