Vivado Adress Editor allows only 32-bit addresses on 64-bit AXI interface
please see the attached screenshot. I have an AXI interface with 64 bit addresses. Still, the Adress Editor only shows 32 bit addresses. I tried running validate_bd_design (-force), replacing Interconnects with SmartConnects, but nothing helped. The 64 bit address width is propagated through the design, still the Address editor persists on only allowing 32 bit.
What am I doing wrong here?
Re: Vivado Adress Editor allows only 32-bit addresses on 64-bit AXI interface
Never mind, the IP Core was packed with the wrong settings.
