Visitor slm_gmail
Vivado Block Diagram - Error in placing module
I hope I'm posting to the right forum, but here goes:
In Vivado 2016.4:  I am trying to place a VHDL module into a block diagram and that VHDL module includes Xilinx IP.  I am getting an error:
ERROR: [filemgmt 56-181] Reference 'TOP_<NAME_OF_MODULE>' contains sub-design file 'D:/.../_ip/BLK_MEM_SP_8B/BLK_MEM_SP_8B.xci'. This sub-design is not allowed in the reference due to following reason(s):  IP references are currently not enabled.
So it seems that my big block of logic that contains a bunch of Xilinx IP blocks (RAM, MCMM, initialized ROM, etc) can't be placed in the block diagram and hooked up to the Zynq processor...  Isn't this a major flaw in the whole FPGA fabric design concept?  Maybe I can  "enable" IP references, as the end of the error message might imply? What gives?
- Cheers, Sam
//Microsemi's Libero has no similar problem hangup.  I don't know about Quartus...
Re: Vivado Block Diagram - Error in placing module
@slm_gmail
Check XCI Inferencing topic in below link at page 221:
https://www.xilinx.com/content/dam/xilinx/support/documentation/sw_manuals/xilinx2019_1/ug994-vivado-ip-subsystems.pdf#page=221
You can package your block which has xci file in it using Vivado IP packager feature and add the custom IP in your block design:
IP Packager User guide: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug1118-vivado-creating-packaging-custom-ip.pdf
Tutorial: https://www.xilinx.com/content/dam/xilinx/support/documentation/sw_manuals/xilinx2019_1/ug1119-vivado-creating-packaging-ip-tutorial.pdf
--Syed
Visitor slm_gmail
Wow.  This is incomprehensibly difficult.  I got it placed by
(1) deactivating all unused items in my project other than the RTL module
(2) packaging RTL into IP.
I tried other ways, it didn't work.  I appreciate the pointers to documentation, but I am NOT going to read 100 pages of Xilinx garbage.  Unfortunately, if this exercise has taught me anything, it is that the Zynq and Vivado are over-designed for nearly all my purposes, and stupidly complicated.  It took deleting and rebuilding entire IP packages just to upgrade them.  I mean, this is horrendous.  I will never recommend Zynq on a platform, ever.
- Sam
