Participant ashikpoojari
Vivado Crash -- Access violation - code c0000005 (first/second chance not available) ntdll!NtGetContextThread+0x14
Vivado abruptly crashes after opening any project. Re-installing Vivado fixes this error for sometime and then reappears. I'm not able to find the exact reason for the error. It starts to appear after a lengthy simulation or implementation run. Until then the vivado works fine. The dump file and the crash report is as follows.
DMP file
Microsoft (R) Windows Debugger Version 10.0.17763.1 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\maverickhp\AppData\Roaming\Xilinx\Vivado\hs_err_pid3564.dmp]
User Mini Dump File: Only registers, stack and portions of memory are available
Symbol search path is: srv*
Executable search path is:
Windows 10 Version 17134 MP (12 procs) Free x64
Product: WinNt, suite: SingleUserTS
17134.1.amd64fre.rs4_release.180410-1804
Machine Name:
Debug session time: Tue Nov 27 16:21:32.000 2018 (UTC - 8:00)
System Uptime: not available
Process Uptime: 0 days 0:20:57.000
This dump file has an exception of interest stored in it.
The stored exception information can be accessed via .ecxr.
(dec.20d0): Access violation - code c0000005 (first/second chance not available)
ntdll!NtGetContextThread+0x14:
00007ffb`d6ccbc54 c3 ret
