Vivado Crash when generating MIG 7series during synthesis in 2018.3 version
I tried to create an HDMI pass-through circuit using Block design.
At that time, I was trying to use MIG 7 Series, but when doing logic synthesis, vivado crashes just after the pop-up of "generating IP" mig 7 series "".
I tried to use the patch according to AR71898, but there is no sign of cure.
Is there any cause?
Thank you in advance.
Mentor
Mentor
Re: Vivado Crash when generating MIG 7series during synthesis in 2018.3 version
Hi @shiraiakira
Do you have a valid license for HDMI ?
I guess that you don't have a valid license for HDMI.
Would you make sure it ?
Best regards,
All I use in the block design is the IP required for the DDR interface.
We use Digilent's IP for HDMI decoding and encoding. Still need a license?
thank you for your reply.
Mentor
Mentor
Hi @shiraiakira
Would you make sure directory path name which has UTF-8 code or space character ?
If yes and using Vivado on Windows10, I suggest you to change working directory.
Best regards,
sorry for the late reply.
My working directory did not contain UTF-8 or spaces. I also tried to change the working directory, but Vivado still crashes.
In addition, I was able to customize IP in Block Design before, but when I try to customize MIG again, Vivado crashes without displaying the customization screen as well (other than MIG) Customization of the IP is possible).
I'm glad I can help because I do not know the solution.
Hello,I have the same problem,have you solved it?
Hello, @windflying
I have not solved this probrem yet.
I'm working on upgrading vivado version to 2019.1. This version does not seem to crash.
Thank you!
