Vivado: Found non local file in project
Hi all,
I'm getting the following critical warning when i try to generate dsa file for my custom sdsoc platform:
CRITICAL WARNING: [Vivado 12-5942] Found non local file in project: /home/boulares/developpment/Vivado/ad_for_sdsoc/hdl/library/xilinx/common/ad_iobuf.v. It is required that all files in the project be imported into the project locally before running write_dsa.
is there a suggestion to fix this problem ?
Thank's.
-Aziz-
Re: Vivado: Found non local file in project
Hi @xilinxacct,
I have copied the nonlocal-declared files into my_project.srcs folder, then i have right-clicked on these files in vivado sources manager and i selected "replace file" option to change their path.
and finally i repeated dsa writing process without any critical warning.
regards
Teacher xilinxacct
@boularesaziz
Is this file 'external' to the project rather than copied/moved local to the project?
Hope that helps
If so, please mark as solution accepted. Kudos also welcomed. :-)
Hi @xilinxacct,
regards
