Scholar drjohnsmith
Vivado GUI bug et on IP / implimentatoin
A small request,
 but thought I'd ask
So stupid me just did.
I have in the Vivado GUI an implimentation running,
    should take about another hour.
Whilst it was chewing,
   decided to look at an IP block in the design,
      noteced a few bugetts, so spent a good half how re setting things inthe IP.
          Now I have come to save the IP, I realise the implimentation is still running.
I clock on cancel the implimentation, the button is grayed out.
    I try to save the IP , may be as a new name, only option is to cancle and loose changes.
Woudl be nice to cover idiotrs like this if preferably the GUI buttons still worked whilst doing othe rthings like editing IP,
    or may be as a less difficult alternative, save , but does not change the data base till the implimentation has finished.
Ta
Re: Vivado GUI bug et on IP / implimentatoin
@drjohnsmith
I guess this feature is available in Vivado.
This is possible if the run is in initilalization phase. Once opt_design will start, user can cancel the run.
Anusheel
Helpful answer -> Give Kudos
Anusheel
Scholar drjohnsmith
Ah
bit I forgot to mention
implimentation had been running for an hour,
   so I'd rather not kill it either,
so no,
 its not fixed in vivado,
Scholar drjohnsmith
bump
