Participant seyyedi
Vivado - Network Address Confilict [BD 41-1377]
Hi all,
in vivado, when I instantiate 2 microblaze plus a processing system I get the following critical message:
 [BD 41-1377] Network address <0x00000000 [ 512M ]> is occupied by different peripherals, </microblaze_1_local_memory/dlmb_bram_if_cntlr/SLMB/Mem> in </microblaze_1/Data> and by </processing_system7_0/S_AXI_GP0/GP0_DDR_LOWOCM> in </microblaze_0/Data>. This is illegal and must be resolved before passing validation
Why I get this message? and how can I resolve it?
Re: Vivado - Network Address Confilict [BD 41-1377]
This is because the microblaze bram is at 0x0 and so is the ps OCM. In my design the instruction AXI wasn't enabled so I didn't see this issue.
If you want to use this topology, you can change the bram address and update the microblaze config to update the boot vector to reflect this change
Participant seyyedi
Even with a processing system and a microblaze with both data and cache memory, I get the following:
 [BD 41-1377] Network address <0x00000000 [ 512M ]> is occupied by different peripherals, </microblaze_0_local_memory/ilmb_bram_if_cntlr/SLMB/Mem> in </microblaze_0/Instruction> and by </processing_system7_0/S_AXI_GP0/GP0_DDR_LOWOCM> in </microblaze_0/Data>. This is illegal and must be resolved before passing validation.
P.S. I need to have S_AXI_GP0 enabled on the processing system in my design.
Participant seyyedi
Here is a snapshot of the Address Editor:
