Observer joe306
Vivado Newbie: Help adding SystemVerilog File as a module to the block design
Hello, I'm new to Vivado and like using the Block Design using modules from my RTL. I have created a project with a Block Design and created a single SystemVerilog file. When I try to add in the file as a module it won't let me. If I choose "Show incompatible modules" from the Add Modules window I do see my module but I don't know why I can't add it to the Block design.
Add_Module.jpgI will also upload my  project. Is SystemVerilog files not allowed?
Joe
Re: Vivado Newbie: Help adding SystemVerilog File as a module to the block design
Hi @joe306,
As per latest UG 994, SV module reference in BD is not supported.  (See below are the limitations of the module ref. feature)
you can only use verilog and VHDL to use the "add module" functionality.
 To integrate your IP in a BD, you can try to instantiate it in a verilog file and then add this verilog file as a module.
hemangd
Scholar watari
Hi @joe306
I confirmed your system verilog file.
Because of this file has a mistake in line 36. So, Vivado can not add this module.
Would you make sure it ?
Best regards,
Observer joe306
I tried with a file that has a Verilog extension and as able to add it to the Block Design, so my guess it that SystemVerilog is only allowed for Simulation.
Comments?
Joe
Observer joe306
I changed the file to
module flip_bit(
    input logic clockin,
    input logic resetin,
    input logic [31:0] data_in,
    output logic [15:0] data_out
endmodule
And still could not add it to the Block Design. Can you try?
Observer joe306
Anyone know if you can and SystemVerilog RTL as a module to a Block Design?
Hi @joe306,
hemangd
Observer joe306
Hello, thanks for responding to my post. Do you know if Xilinx has plans to fix this in the future?
Observer joe306
Hello, one more question. Can you recommend any documentation that will help me learn how to package the SystemVerilog File as an IP and then import the IP to the block diagram?
Joe
Hi @joe306,
Have a look in UG 994, 896.
hemangd
Observer joe306
Thank you
I'm facing the same issue. Would wrapping the SV module under a verilog module work? Has anyone tried it? Thanks.
Answering my own question here, yes, I can wrap SV in verilog to use in the block design.
