rdrehmel
Vivado: Normal project vs. packaging project
Is it correct that manually adding
<File Path="...PATH.../component.xml">
  <FileInfo SFType="IPXACT"/>
</File>
to the <FileSet> with the attribute Type="DesignSrcs" of a Vivado project file (.xpr) is currently the
only way to unlock the "Package IP" button in the GUI in the original development project? I prefer
to have a single project to do simulation and IP packaging in.
