edwinj_mav
Vivado : Synthesis goes Out of Date when I open Block Design
If a synthesis of a Project is complete and If I open the BD, then the synthesis goes out of date and if I re -run synthesis , the synthesis fails and says missing components. I want to know
1) Why does synthesis go out of date when I just open the BD ?
2) Due to the above I am getting Synthesis issue sin any post runs. The only way everything is successful is if I do fresh check out from my repo, open BD , make necessary changes save it and then run synthesis. If I close and reopen synthesis out of date.
Any help would be much appreciated.
maps-mpls
Mentor
Mentor
I do not know, but try to reset your OOC runs (see your design runs design_1, impl_1, and synth_1...right click each).  Open your BD then Validate and close the BD.  The in the flow navigator go to settings->IP and hit the clear cache.  Then synthesize.  Wait until the output products are generated (the first time at least, just for superstition--probably not necessary).  Then open and close your BD without making any changes.
If you're still having trouble, I do not know.  I open block diagrams all the time while synthesizing without the behavior you're describing.
*** Destination: Rapid design and development cycles ***
edwinj_mav
Hi maps-mpls,
Generally the other projects that I have which have BD do not have this issue. However 1 project has this issue.
No, its still not working.
hemangd
@edwinj_mav
Which Vivado version are you using?
Is it possible to share your archived project or a small testcase that can reproduce this issue?
If yes, I can arrange a secure ftp through which you can share it.
hemangd
