digitalone
Vivado Webpack ARTY Board not listed
I justed installed Vivado 2015.4 with Webpack License.
I did "Create New Project" -> "RTL Project" with "Do not specify sources at this time" checked.
On the "Default Part" page I clicked on "Boards".  There are only (3) in the list:
ZedBoard...
Artix-7 AC701... with XC7A200T... part
ZYNQ-7ZC702 ...
The ARTY board is not listed.  I had expected it would be.  Is this because I am using Webpack?
Is there a way to install the ARTY board into Vivado so it would be listed here?
nupurs
Hi @digitalone,
Only Xilinx evaluation boards are listed under boards.
Please choose correct package from parts.
Arty xc7A35T is supported in Vivado 2015.4 webpack.
Nupur
Nupur
smarell
Community Manager
Community Manager
Please follow the procedure given in https://reference.digilentinc.com/vivado:boardfiles2015 to add Arty board to Vivado.
pratham
@digitalone Digilent link seems to be broken. When it is up just download the board files. There are very simple 2 stpes you have to do.
1) Just download the arty board files (make sure it has 3 xml files)
2) copy and paste the folder with name ARTY here C:\Xilinx\Vivado\2015.4\data\boards\board_files
Start the vivado and go to board tab, you would see your board listed under board tab.
-Pratham
nsultana
This solution worked for me. Thank you very much.
