petemar
Vivado: XCVU440 Part Not Listed
I'm creating a new project and the xcvu440 part is not listed in the drop-down menu.
This is with the full version of Vivado 2019.1.  What's required to target an Ultrascale part?
ansarimo
Hi @petemar ,
As can be seen in the snapshot below, I have XCVU440 listed at my end on Vivado 2019.1:
Please check if you have all the devices installed at your end, this can be checked by Opening Vivado --> Help --> Add Design Tools or Devices...:
If Ultrascale devices are not installed then install them and check if still, you are facing the same issue.
Hope this helps.
Thanks and Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
