Advisor
Advisor
Vivado - automatically set working directory to the current (opened) project directory
Whenever I open a project via the Vivado IDE (2015.4) , the 'working directory' is set to C:/Users/MyName/AppData/Roaming/Xilinx/Vivado (using the tcl command 'pwd')
Can this working directory be changed automatically to the open project directory? Is there some IDE option for this? I.e. the location of the .xpr file? For example .jou files are written to this location etc.
However when executing for example write_project_tcl, it writes the file to C:/Users/MyName/AppData/Roaming/Xilinx/Vivado, which is not what you want. And it's quiet annoying to change it each through the tcl window...
@ronnywebers,
Some ways of changing the CWD to the current project directory are listed below:
    • Invoke Vivado tools from command line while in the project directory .
    • Double-click on the .xpr project file in Windows Explorer. This will open the project in Vivado IDE and the project directory will be used as the working directory.
    • A command to CD to the current project directory could be added as a proc in the init.tcl file.
      • Example: after adding the following proc to the init.tcl, a user can type cdp from the Tcl console to change the CWD to the project t to the current working directory.
        proc cdp { } {
        cd [get_property DIRECTORY [current_project]]
      • One user suggests creating a button (Tools > Custom Commands) to generate report files.
# SETS THE WORKING DIRECTORY TO THE PROJECT SO THAT IF YOU GENERATE FILES THEY ARE WRITEN TO THE DIR
set work_directory [get_property DIRECTORY [current_project]] ; cd $work_directory ; puts -nonewline "Changing Directory to " ; pwd
See also (Xilinx Answer 55459)
--Syed
This can be done from Vivado GUI as shown below.This can be accessed from Tools-> Options
Anirudh
Advisor
Advisor
thanks @athandr, I think that is what I'm looking for - didn't know about these options.
However, I would expect that 'last project's directory' would mean just this ... or that there would be an option like 'current project directory'.
I asume if I go for 'specify project directory', I still need to adjust this when I switch from project A to project B ...?
@ronnywebers
For 'specify project directory' The setting will be stored and it will remain same for the directory specified.
From UG893:
Default Project Directory: Specifies where the Vivado IDE searches for existing projects, and where it writes newly created projects.
--Syed
You can change the start location in the properties in the short cut link.
It looks like these solutions only work for the invocation of Vivado and only for a one project.  If you are working on multiple projects (Who isn't?) your out of luck. If you change projects from within Vivado, the working directory stays pointing to the old project.  Also if you are in a source code controlled environment they don't work unless everyone has the exact same directory structure.  That is particularily difficult when some use linux and some use windows as the directory structures are inherently different.  I use both often for the same project.
I added a tcl script file containing:  cd [get_property DIRECTORY [current_project]] to all my project directories. I also drop the script into other directories that might become a Vivado startup directory.
As long as I, somehow, get the cwd to point to the current project directory some time before I change projects, I can source that script (which will taken from the old directory) after I change to the new project.  Quite a PIA, especially given how easy it would be for the tool to do this automatically!
