mzl20
Vivado: command not found even after sourcing
I am very new to this so I am sorry if there are certain rules/ practices that I am not following. I am trying to use vivado for a python project. Even after sourcing settings64.sh it says  vivado: command not found. Is there any reason for this?
My terminal output is:
mze@mze-VirtualBox:~$ source /home/mze/Desktop/Xilinx/Vivado/2020.2/settings64.sh
mze@mze-VirtualBox:~$ vivado
Thanks in advance for any form of help!
amaccre
Hi @mzl20 ,
If you cd to the directory do you see the settings64.sh file, just in case the directory is wrong.
If you do, can also try running: ./settings64.sh
You can also check if the environmental variables are set up by typing env and looking for XILINX_VIVADO e.g.
env | grep XILINX
You should see the path to where it is installed.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
