Vivado encrypted code causes error while implementing
I get IEEE 1735 v2 encryption license for Vivado 2018.3 and it works with Xsim simulation,
but it causes error with synthesis. Any solutions?
[Vivado project error]
INFO: [Common 17-83] Releasing license: Synthesis
362 Infos, 275 Warnings, 8 Critical Warnings and 0 Errors encountered.
synth_design completed successfully
synth_design: Time (s): cpu = 00:00:50 ; elapsed = 00:00:52 . Memory (MB): peak = 2425.617 ; gain = 1054.207 ; free physical = 236 ; free virtual = 42566
# write_edif -force -security_mode all ${module}.edn
ERROR: [Designutils 20-2284] Design protected by IEEE 1735 V2  may not be written to EDIF
INFO: [Common 17-206] Exiting Vivado at Sat May 11 11:51:10 2019...
[Error from license server]
11:39:19 (xilinxd) OUT: "EncryptedWriter_v2" adki@AndoUbuntu
11:39:19 (xilinxd) IN: "EncryptedWriter_v2" adki@AndoUbuntu
11:42:15 (xilinxd) UNSUPPORTED: "Internal_bitstream" (PORT_AT_HOST_PLUS   ) adki@AndoUbuntu  (No such feature exists. (-5,346))
For your information, I used following settings.
[Key-File]
`pragma protect version = 2
`pragma protect encrypt_agent = "XILINX"
`pragma protect encrypt_agent_info = "Xilinx Encryption Tool 2017"
`pragma protect begin_commonblock
`pragma protect control error_handling = "delegated"
`pragma protect control decryption=(activity==simulation) ? "true" : "true"
`pragma protect end_commonblock
`pragma protect begin_toolblock
`pragma protect rights_digest_method="sha256"
`pragma protect key_keyowner = "Xilinx", key_keyname= "xilinxt_2017_05", key_method = "rsa", key_public_key
MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAxngMPQrDv/s/Rz/ED4Ri
j3tGzeObw/Topab4sl+WDRl/up6SWpAfcgdqb2jvLontfkiQS2xnGoq/Ye0JJEp2
h0NYydCB5GtcEBEe+2n5YJxgiHJ5fGaPguuM6pMX2GcBfKpp3dg8hA/KVTGwvX6a
L4ThrFgEyCSRe2zVd4DpayOre1LZlFVO8X207BNIJD29reTGSFzj5fbVsHSyRpPl
kmOpFQiXMjqOtYFAwI9LyVEJpfx2B6GxwA+5zrGC/ZptmaTTj1a3Z815q1GUZu1A
dpBK2uY9B4wXer6M8yKeqGX0uxDAOW1zh7tvzBysCJoWkZD39OJJWaoaddvhq6HU
MwIDAQAB
`pragma protect control xilinx_configuration_visible = "true"
`pragma protect control xilinx_enable_modification = "true"
`pragma protect control xilinx_enable_probing = "true"
`pragma protect control xilinx_enable_netlist_export = "true"
`pragma protect control xilinx_enable_bitstream = "true"
`pragma protect control decryption=(xilinx_activity==simulation) ? "true" : "true"
`pragma protect end_toolblock = ""
Re: Vivado encrypted code causes error while implementing
Hi @andoki ,
-- Are you trying to write netlist (EDIF) of the encrypted source file? If yes, then i dont think it is possible to use write_edif for writing netlist. Please use write_verilog or write_vhdl to write the netlist for encrypted sources.
Please refer the below posts :
https://forums.xilinx.com/t5/Design-Entry/Encrypting-netlist-as-edn-in-Vivado/td-p/868675
https://forums.xilinx.com/t5/Design-Tools-Others/IEEE1735-encryption-and-EDIF/td-p/762851
Thanks & Regards,
Sravanthi B
Hi @andoki ,
Thanks & Regards,
Sravanthi B
