Vivado generate verilog module when custom ip
Hi friend,
Previously we use ISE to generate ip and we can get verilog file.
Now we want to use vivado to speed up the implementation. But after customing IP, the module file type is VHDL. We are not familiar to VHDL, it there any method to generate verilog module from vivado?
In the project settings check what is the target language has been set to?
If it has been set to VHDL try changing it to verilog and generate the output products for IP again.
By default vivado will gnearte the top level IP products according to the project target language.
If you set the target language as VHDL the top level file will be generated in VHDL but still the lower level files will be generated in vhdl or verilog depending on how the core is coded.
Which IP are you generating and seeing this issue.
Can you paste a snapshot of it.
Satish
Please check this AR
http://www.xilinx.com/support/answers/51041.html
Ashish
http://forums.xilinx.com/t5/Design-Entry/how-to-generate-blk-ram-ip-within-verilog-in-vivado/m-p/336805#M3923.
cust_ip
IP_vhdl
