Voyager
Voyager
Vivado implementation always out dated when reopen.
I have a project automatic upgraded from lower version, the compilation status won't keep. Every time I reopen the project, status is out-of-date.
Same source, if I recreate the project from .tcl, issue goes away.
I had tried compare write project .tcl script in both projects. The major difference seems to be the variable of
orig_proj_dir
In the project won't keep status the variable is long, recreated project this variable is short.
Just curious, if there is a magic switch to correct the problematic project.
Re: Vivado implementation always out dated when reopen.
Hi @legendbb ,
Firstly, Have you saved your project in the vivado latest version you migrated to or using the same project as read only?
If yes then try to save the project then run synthesis & implementation in vivado latest version you migrated to. Now if you close then it will start from the same state.
If that doesn't worked the you can force the processes to up to date as a work around:
Open the project in vivado. In the upper right-hand corner, click on "more info" and then "Force up-to-date". This step will prevent the tools from re-synthesizing and re-implementing the design.
Raj
Hi @legendbb ,
Raj
