Observer mreisteremp
Vivado ip file group relative path
I am having an issue when adding some VHDL sources file to my IP file group when creating a new VIVADO IP design.
When I add my files to the file group it adds the absolute path and not the relative path. I want to add the relative path.
I have found this article:
http://www.xilinx.com/support/answers/56102.html
 That says in order to add the file using the relative path the file needs to be available inside the project/srcs/ip directory. At least it says this for .coe files… I assume this applies to all files as well.
So a question.
  • Do I really need the files in a directory called srcs/ip directory in order for the ip packager to add the files using a relative path name? IF so should I manual create this or is the tools supposed to create this for me?
I suspect I don’t really need to add the files like this since I have the AXI wrapper files that my tools generated automatically in a directory other than this one and them a referenced using a relative path. I also have about 5 other ip project that I have don’t where the added files are referenced using a relative path and none of them are in this “srcs/ip directory” directory structure.
So another question
How do I get vivado to add my files using a relative path?
The tool even warns me that I am not using a relative path, but I doesn’t allow my to add a file using a relative path.
I have attached a screen shot for conveince. The files ADC_READER_v1_0_S00_AXI.vhd, ADC_READER_v1_0_S00_AXIS.vhd, ADC_READER_v1_0.vhd are in the same directory as the files that are being added as a absolute path.
Re: Vivado ip file group relative path
ok update.
I went into my component.xml file and manual edited it to use the reltive path and everything works..............
But why is vivado not adding these files using a relative path? Why do i have change to component.xml manually?
Please check this thread.
http://forums.xilinx.com/t5/Design-Entry/Is-it-possible-in-Vivado-to-package-a-custom-IP-with-relative/td-p/488200
Thanks,Vijay
