Observer silvaurus
Vivado 'module not found' Error for a user-defined IP inside of another IP
Hi!
Could you help me figure out what causes this error?
Software Used: Vivado 2018.3
Design flow:  (1) Create a project A, which is a fairly large project with a AXI master output. Pack A to be IP_A. (2) Create an AXI peripheral wrapper IP_B, inside of this project using IP_A (I want to have a general AXI peripheral interface so I wrap A with a AXI wrapper) I've also tried just defining the entire project A directly in this AXI peripheral interface, and the problem remains. (3) Create a block design, connecting Zynq SoC with IP_B, generating output products.
Error: module 'IP_A' not found.
Error description: It seems like IP_A can not be found even it is used in IP_B.
I have tried: (1) In generating IP_A, copy all the source files to the IP. (2) Adding a separate IP_A instance to the project that I used for block design. (3) Adding the path of IP_A to the IP repository searching path. The problem still remains.
Thanks a lot!
Observer silvaurus
Re: Vivado 'module not found' Error for a user-defined IP inside of another IP
Sorry, problem resolved.
When I created the AXI peripheral IP, I added user logics to the top module (IP_NAME_v1_0.v). They should have gone to one layer below, to the IP_NAME_v1_0_X_AXI.v file.
Observer silvaurus
The reason why I defined an AXI peripheral wrapper IP_B for A is also that in Tools-> Create and Package new ip -> Create a new AXI4 peripheral it can only add files but not directories. Since the design A includes multiple directories I just wrap it as IP_A first.
I did try using tcl command to add all the source files to the AXI peripheral project directly, so as to getting rid of IP_A, and when I add this peripheral IP to block design, the result seems to be the same: The submodules inside of this AXI peripheral is not found.
I guess to better describe this question, it might be something that I did wrong in building an AXI peripheral IP...
Observer silvaurus
Found in Setting->IP->Packager the Default Library is set to be 'user', while in the block design, the ip shown in Sources (with a red question mark indicating not found) actually looks like 'xil_defaultlib.xxxx'. Could that be the cause?
Observer silvaurus
Sorry for the confusion. I tried some more things today and found it's just that if I wrap a user-defined IP outside another user-defined IP, then the inner one will be reported as 'not found' in application. I'm wondering if there are something wrong that I did during packaging could lead to this.
Thanks a lot!
Observer silvaurus
