jcabel
Vivado names AXI IP projects with illegal characters
Inside of a Vivado project I create a new AXI4 peripheral IP
I give it a name, configure the ports (a master AXI stream) and edit it.
Vivado opens a new window.I add my logic to the core and a testbench.
When I want to simulate it it fails. The reason is it (not me) created a folder (myip_1.0) and the '.' is not allowed. Wonderful.
How can I go around this?
maps-mpls
Mentor
Mentor
I can confirm the problem in Vivado 2020.1  (But I do not work at Xilinx, hopefully somebody who has actual responsibility will come by and not only confirm, but submit a change request).
In the meantime, when you create and package new IP in the graphical user interface (GUI), note that tcl commands are issued.  Copy them, bring them into a text editor, and modify.  For example the following seems to work for me:
create_peripheral morgan-aps.com user myip 1.0 -dir C:/some_dir_you_use/maps_ip_repo/managed_ip_project/../Managed_IP
add_peripheral_interface S_AXIS -interface_mode slave -axi_type stream [ipx::find_open_core morgan-aps.com:user:myip:1.0]
add_peripheral_interface M_AXIS -interface_mode master -axi_type stream [ipx::find_open_core morgan-aps.com:user:myip:1.0]
generate_peripheral [ipx::find_open_core morgan-aps.com:user:myip:1.0]
write_peripheral [ipx::find_open_core morgan-aps.com:user:myip:1.0]
set_property  ip_repo_paths  {C:/some_dir_you_use/maps_ip_repo/managed_ip_project/../Managed_IP/myip_1.0} [current_project]
update_ip_catalog -rebuild
ipx::edit_ip_in_project -upgrade true -name edit_myip_v1_0 -directory C:/some_dir_you_use/maps_ip_repo/managed_ip_project/../Managed_IP C:/some_dir_you_use/maps_ip_repo/Managed_IP/myip_1.0/component.xml
# Above was captured from GUI.
# After closing the new project that doesn't allow simulation, and deleting all of the generated files from the managed IP project and the disk drive,
# Copy the above into a text editor, and change the above (note RED) to the following (note RED)
create_peripheral morgan-aps.com user myip 1 -dir C:/some_dir_you_use/maps_ip_repo/managed_ip_project/../Managed_IP add_peripheral_interface S_AXIS -interface_mode slave -axi_type stream [ipx::find_open_core morgan-aps.com:user:myip:1] add_peripheral_interface M_AXIS -interface_mode master -axi_type stream [ipx::find_open_core morgan-aps.com:user:myip:1] generate_peripheral [ipx::find_open_core morgan-aps.com:user:myip:1] write_peripheral [ipx::find_open_core morgan-aps.com:user:myip:1] set_property ip_repo_paths {C:/some_dir_you_use/maps_ip_repo/managed_ip_project/../Managed_IP/myip_1} [current_project] update_ip_catalog -rebuild ipx::edit_ip_in_project -upgrade true -name edit_myip_v1_0 -directory C:/some_dir_you_use/maps_ip_repo/managed_ip_project/../Managed_IP C:/some_dir_you_use/maps_ip_repo/Managed_IP/myip_1/component.xml
Turn it into a tcl script if desired, or paste it into the tcl console.
Kludgy, but short of creating a separate project just for simulating, it's all I got until a person paid to monitor these posts swings by with a better suggestion.
I hope this helps.
*** Destination: Rapid design and development cycles *** Unappreciated answers get deleted, unappreciative OPs get put on ignored list ***
chinmays
Hi @jcabel,
dot is not allowed in directory name when it is used as a terminal character (refer to Vivado naming convention).  In myip_1.0, dot is not terminal. Please let me know what error are you facing while simulation, if it is due to this dot, I will report it to development.
~Chinmay
maps-mpls
Mentor
Mentor
Hey @chinmays thanks for that gentle reminder.
@jcabel you might want to close this issue.   I doubt they will change the supported file or directory naming convention.
