Vivado on Ubuntu
i am recently working in new environment with linux and virgin about linux stuff, i just succeeded install vivado on my ubuntu, when i start a new project with arty a7 board and drop the fundamental component clock wizard , i got this cric. error : [IP_Flow 19-973] Failed to create IP instance 'design_1_clk_wiz_0_0'. Error during customization.
could someone please, give a help
thanks
Hi wisnuk@w ,
Have a look into this thread. https://forums.xilinx.com/t5/Synthesis/Vivado-2018-3-fails-OOC-synthesis-of-Memory-Block-Generator-8-4/m-p/951318#M30384
This may help you out.
hemangd
Hi wisnuk@w ,
Are you facing any warning or critical warnings related to .xml file? If yes, please post it here.
Also post other critical warnings or warnings/errors which you face.
hemangd
idk about .xml file you mean. but it get worse , i got 90 errors :[#UNDEF] conversion to double from string is failed. i got this also :ERROR: [#UNDEF] conversion to double from string is failed
unexpected "," outside function argument list
in expression "1000 / 10,000"
100,000
in expression "(10.000 / 1.0) * 100,000"
10,000
in expression "(10,000 - 10.0)"
0,010
0,010
in expression "1000.000 / 2,155"
100,000
10,000
0,010
0,010
100,000
10,000
0,010
0,010
100,000
10,000
0,010
0,010
[Constraints 18-638] Undefined BOARD_PART property for current project while applying board-derived constraints. ["/home/bpptpte/Desktop/FPGA/Arty_Linux/Arty_Linux.srcs/sources_1/bd/design_1/ip/design_1_clk_wiz_0_0/design_1_clk_wiz_0_0_board.xdc":3]
[IP_Flow 19-182] Failed to load BOM file '/home/bpptpte/Desktop/FPGA/linux_arty/linux_arty.srcs/sources_1/bd/design_1/ip/design_1_clk_wiz_0_0/design_1_clk_wiz_0_0.xml'.
[IP_Flow 19-182] Failed to load BOM file '/home/bpptpte/Desktop/FPGA/linux_arty/linux_arty.srcs/sources_1/bd/design_1/ip/design_1_lmb_bram_0/design_1_lmb_bram_0.xml'.
[IP_Flow 19-183] Failed to load IP instance 'design_1_clk_wiz_0_0'.
[IP_Flow 19-183] Failed to load IP instance 'design_1_lmb_bram_0'.
[IP_Flow 19-1835] Failed to recreate IP instance 'design_1_clk_wiz_0_0'. Error reading project file(s).
[IP_Flow 19-1835] Failed to recreate IP instance 'design_1_lmb_bram_0'. Error reading project file(s).
those also
Hi wisnuk@w ,
hemangd
i'm sorry a little bit spam , but i really need a help. following is xml file content :
<?xml version="1.0" encoding="UTF-8"?>
<Root MajorVersion="0" MinorVersion="36">
<CompositeFile CompositeFileTopName="design_1" CanBeSetAsTop="false" CanDisplayChildGraph="true">
<Description>Composite Fileset</Description>
<Generation Name="SYNTHESIS" State="STALE" Timestamp="1554290970"/>
<Generation Name="IMPLEMENTATION" State="STALE" Timestamp="1554290970"/>
<Generation Name="SIMULATION" State="STALE" Timestamp="1554290970"/>
<Generation Name="HW_HANDOFF" State="STALE" Timestamp="1554290970"/>
<FileCollection Name="SOURCES" Type="SOURCES">
<File Name="ip/design_1_clk_wiz_0_0/design_1_clk_wiz_0_0.xci" Type="IP">
<Instance HierarchyPath="clk_wiz_0"/>
<Properties IsEditable="false" IsVisible="true" Timestamp="0" IsTrackable="true" IsStatusTracked="true"/>
<Library Name="xil_defaultlib"/>
<UsedIn Val="SYNTHESIS"/>
<UsedIn Val="IMPLEMENTATION"/>
<UsedIn Val="SIMULATION"/>
</File>
<File Name="ip/design_1_mig_7series_0_0/design_1_mig_7series_0_0.xci" Type="IP">
<Instance HierarchyPath="mig_7series_0"/>
</File>
<File Name="ip/design_1_axi_uartlite_0_0/design_1_axi_uartlite_0_0.xci" Type="IP">
<Instance HierarchyPath="axi_uartlite_0"/>
</File>
<File Name="ip/design_1_axi_gpio_0_0/design_1_axi_gpio_0_0.xci" Type="IP">
<Instance HierarchyPath="axi_gpio_0"/>
</File>
<File Name="ip/design_1_microblaze_0_0/design_1_microblaze_0_0.xci" Type="IP">
<Instance HierarchyPath="microblaze_0"/>
</File>
<File Name="ip/design_1_dlmb_v10_0/design_1_dlmb_v10_0.xci" Type="IP">
<Instance HierarchyPath="microblaze_0_local_memory/dlmb_v10"/>
</File>
<File Name="ip/design_1_ilmb_v10_0/design_1_ilmb_v10_0.xci" Type="IP">
<Instance HierarchyPath="microblaze_0_local_memory/ilmb_v10"/>
</File>
<File Name="ip/design_1_dlmb_bram_if_cntlr_0/design_1_dlmb_bram_if_cntlr_0.xci" Type="IP">
<Instance HierarchyPath="microblaze_0_local_memory/dlmb_bram_if_cntlr"/>
</File>
<File Name="ip/design_1_ilmb_bram_if_cntlr_0/design_1_ilmb_bram_if_cntlr_0.xci" Type="IP">
<Instance HierarchyPath="microblaze_0_local_memory/ilmb_bram_if_cntlr"/>
</File>
<File Name="ip/design_1_lmb_bram_0/design_1_lmb_bram_0.xci" Type="IP">
<Instance HierarchyPath="microblaze_0_local_memory/lmb_bram"/>
</File>
<File Name="ip/design_1_xbar_0/design_1_xbar_0.xci" Type="IP">
<Instance HierarchyPath="microblaze_0_axi_periph/xbar"/>
</File>
<File Name="ip/design_1_microblaze_0_axi_periph_0/design_1_microblaze_0_axi_periph_0.xci" Type="IP">
<Properties IsEditable="false" IsVisible="false" Timestamp="0" IsTrackable="true" IsStatusTracked="true"/>
</File>
<File Name="ip/design_1_microblaze_0_axi_intc_0/design_1_microblaze_0_axi_intc_0.xci" Type="IP">
<Instance HierarchyPath="microblaze_0_axi_intc"/>
</File>
<File Name="ip/design_1_microblaze_0_xlconcat_0/design_1_microblaze_0_xlconcat_0.xci" Type="IP">
<Instance HierarchyPath="microblaze_0_xlconcat"/>
</File>
<File Name="ip/design_1_mdm_1_0/design_1_mdm_1_0.xci" Type="IP">
<Instance HierarchyPath="mdm_1"/>
</File>
<File Name="ip/design_1_rst_clk_wiz_0_100M_0/design_1_rst_clk_wiz_0_100M_0.xci" Type="IP">
<Instance HierarchyPath="rst_clk_wiz_0_100M"/>
</File>
<File Name="ip/design_1_axi_smc_0/design_1_axi_smc_0.xci" Type="IP">
<Instance HierarchyPath="axi_smc"/>
</File>
<File Name="ip/design_1_rst_mig_7series_0_83M_0/design_1_rst_mig_7series_0_83M_0.xci" Type="IP">
<Instance HierarchyPath="rst_mig_7series_0_83M"/>
</File>
</FileCollection>
</CompositeFile>
</Root>
