Vivado v2017.4.1 crashed while setting up new project in IDE
Please find the debug and log files in the attachments section for you to analyze.
Re: Vivado v2017.4.1 crashed while setting up new project in IDE
Hello @mbianconi,
What OS are you seeing this crash on? Window 10? Can you confirm on this please? Thanks
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hello @anatoli,
No, it's not Windows 10. As shown in the crash report file vivado_pid10818.str (already included in the attached zip), the OS is:
OS: CentOS release 6.9 (Final)
OS Version: 2.6.32-696.30.1.el6.x86_64
OS Architecture: amd64
Available processors (cores): 8
Actually, it happened only once and I am not worried about it. I sent you the data because I was prompted to by a message from the tool (see also the vivado_pid10818.debug file).
Best,
Maurizio
