WARNING:ProjectMgmt when i change package
hi everyone:
i use ise 14.7
when i change the spartan6 package from  "ftg256" to  "cpg196", i re implemnet the project, download the design file, everything works well until now.
but when i reopen then project, the following warnings show:
WARNING:ProjectMgmt - The device settings for core 'div_1' do not match the ISE project settings.
Package mismatch "ftg256" vs. "cpg196"
does these warning matters?
how to fix them?
回复: WARNING:ProjectMgmt when i change package
You can ignore the warning as only package is changed. The generated netlist for the IP should be compatible.
Try re-generating the IP core under the current project setting.
is that ok if i ignore the warning? i already use the project in the product before i notice the warning. and until now it works ok
