Warning: X locale modifiers not supported, using default
Hello all,
I performed a fresh install of Vivado 2017.2 on Ubuntu 16.04.1 LTS.  When launching Vivado, i get the following.
What does this warning signify?
# Vivado v2017.2 (64-bit)
# SW Build 1909853 on Thu Jun 15 18:39:10 MDT 2017
# IP Build 1909766 on Thu Jun 15 19:58:00 MDT 2017
# Start of session at: Tue Oct  9 16:13:58 2018
# Process ID: 10717
# Current directory: /home/zynqdev/Zynq/2017_2/install_test
# Command line: vivado
# Log file: /home/zynqdev/Zynq/2017_2/install_test/vivado.log
# Journal file: /home/zynqdev/Zynq/2017_2/install_test/vivado.jou
start_gui
xterm: Failed to open input method
Thanks, Christiaan
** kudo if the answer was helpful **
** accept as solution if your question is answered **
Re: Warning: X locale modifiers not supported, using default
It seems that the warnings are only there at the first launch, so I guess it's harmless...
# Start of session at: Thu Oct 11 16:13:30 2018
# Process ID: 9008
start_gui
exit
INFO: [Common 17-206] Exiting Vivado at Thu Oct 11 16:14:23 2018...
Christiaan
# Process ID: 9008
start_gui
exit
Christiaan
