Observer mcmontague
Warning message: "IP is locked. Locked reason: User override"
I am getting Synthesis warnings related to IP I'm using, e.g.:
  [IP_Flow 19-2162] IP 'fifo_generator_0' is locked. Locked reason: User override
I recently upgraded from Vivado 2013.1 to 2013.2, and updated all the IP. I believe this is when I started seeing this message. The IP status says all source files are "Up-to-date".
I just want to understand what this warning is about.
Mike M.
Scholar pratham
Re: Warning message: "IP is locked. Locked reason: User override"
Check this thread
http://forums.xilinx.com/t5/Design-Entry/Vivado-2013-2-synthesis-message-Xilinx-IP-preload-is-disabled/td-p/331739
-Pratham
