Anonymous
Not applicable
What I/O standard should be used for PERTSn pins in xcku040-fbva676
is it possible to use 3.3 on this pin?
for what "mange ip" tool create i can understand that the recommendation is 1.8V (for PCIE xdc file)
thanks
Hello @Anonymous,
Please check below AR
http://www.xilinx.com/support/answers/61492.html
Ashish
Hello @Anonymous,
Have you checked the answer record? Did that help?
Ashish
