Observer qiuxiaojie
What do these IP icons indicate?
Hello everyone,
Could you explain to me what these icons of the following IPs mean?
The icon of these IPs looks like a key.
    axi_cpu_interconnect
    axi_hdmi_interconnect
    axi_mem_interconnect
The icon of these IPs is a question mark.
    ila_0
    scope_0
Thanks a lot!
Re: What do these IP icons indicate?
Hi @qiuxiaojie
Question mark indicates that the file is missing.
Key symbol indicates hidden instantiation. Refer to page-51 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_3/ug893-vivado-ide.pdf
Deepika.
Deepika.
@qiuxiaojie
?: File missing, Regarding the mark on .v file: Click on the file and check property. I guess, it should be locked or read only.
Anusheel
Helpful answer -> Give Kudos
Anusheel
Observer qiuxiaojie
Could you tell me what is the meaning of "hidden instantiation"?
Observer qiuxiaojie
after "Generate Output Products" is completed,
1. IPs with key symbol before still have this symbol now.
2. IPs with question mark have a normal symbol. There are not any IPs with question mark.
3. some of IPs have a cross symbol indicating that the version of the IP is in the IP Catalog, and synthesis targets are generated.
4. The other IPs have a normal symbol.
What are reasons for these four situations?
Hi @qiuxiaojie
Can you open block design and run write_bd_tcl command from tcl console? Attach the resultant TCL file here.
Deepika.
Deepika.
Observer qiuxiaojie
Hello @vemulad,
My TCL file has been attached.
qiuxiaojie.
